Wall tiles are getting bigger and bigger aren't they!!!!
I currently recommend powdered fastset flexible adhesive to stick them to walls.
Does anyone else know of a good product that doesn't cost the earth?
600x600 PORCELAIN WALL TILES
- Has thanked: 39 times
- Been thanked: 621 times
Re: 600x600 PORCELAIN WALL TILES
600 x 600.....................got any other info on the correct adhesive. Two part perhaps??
2 part would be quite extreme, 2 part flexes well for wooden floors but would it grip any better? Not sure myself. I think its just a case of take your time with these big tiles.
So your cheap adhesive limits the amount that the tiles may curl then, as it can often be a problem on tiles 600X600 and upwards??
Two part is certainly not extreme for those size and larger.
