Tiling onto plasterboard
new diy-er
Has thanked: 5 times
Post by new diy-er »
I am planning to tile my Kitchen within the next few weeks, but there are some areas which are plasterboard. Is it ok to put tile adhesive straight onto plasterboard or will the board suck the moisture from the adhesive too quickly?
Apologies if this is a dumb question, i just want to be sure.
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Tiling onto plasterboard
Post by royaloakcarpentry »
You need to cover the plasterboards with a primer before tiling. The best primer to use will be the one which is recommended by the adhesive manufacturer.
Do not use PVA.
These users thanked the author royaloakcarpentry for the post:
new diy-er
tictic
Been thanked: 23 times
Post by tictic »
depends on what adhesive you use also,if the tiles arnt that big over 250-300mm,then you can use a good branded tubbed adhesive..mapei/weber/bal/ardex etc..and these come with the acrylic already in the mix,so no priming is needed.
These users thanked the author tictic for the post:
new diy-er
Return to “Tiling Forum”
