Hi all,
I have just had my bathroom retiled, when I applied grout sealant it seemed to crack the grout, does anyone know why this has happened or what I can do to rectify it?
Grout sealant has cracked the grout
- Has thanked: 39 times
- Been thanked: 621 times
Re: Grout sealant has cracked the grout
it shouldn't crack the grout. If it is showing cracks along internal corners then they may already have had some cracking and the sealer is just highlighting them.
Or is this a problem in other areas too such as middle of wall etc.
I take it you have applied and cleaned off excess sealer?? Also, some sealers recommend 2 coats.
