Sympathetic tile removal?
gib_goblin
Has thanked: 7 times
Been thanked: 8 times
Post by gib_goblin »
I'm about to start removing tiles from our old shower. They're standard white 6/6 tiles. Stuck on properly (not dot-dabbed!)
My concern is the wall; it's made of old 9" solid bricks with lime mortar that has all but turned to dust. The mortar is held in place by the surface plaster - which the tiles are fixed too. What is the most gentle or least destructive way of removing the tiles, so that the bricks don't get knocked loose?
Don't buy a dwarf with learning difficulties,
It's not big and it's not clever.
ashleywood.ash
Has thanked: 9 times
Been thanked: 10 times
Re: Sympathetic tile removal?
Post by ashleywood.ash »
should be ok once you get the first tile off as then I would use a wide thin chizel and tap down the back of the tiles to get them off 1 by one.
if they really are stuck on tight the weakest point will be the grout imo. so chizel out a section of grout on the first tile (or use a grinder if you are scared of hitting with hammer) just go deep enough to get thin chizel a little behind the first tile and prize off then you are home free :-)
thats the way i would go anyway unless anyone else knows better as I am hobby tiler its not my proff
These users thanked the author ashleywood.ash for the post:
gib_goblin
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
well i dont normally advocate this but you could tile over! providing the originals ARE STUCK FAST
IF IT WERE EASY ITD B BORING!
ashleywood.ash
yeah thats what they do on changing rooms :lol:
marc1106
Post by marc1106 »
ashleywood.ash wrote:yeah thats what they do on changing rooms :lol:
if Gib gob knows the original tiles are well fixed and its gonna cause aMAJOR structual issue trying to remove them, then id say clean em up and go for an over tile, my only concern would be weight of tile!
gib_goblin
Thanks Ashley, your idea works. I used a trowel to get under the edges and that 'cuts' the adhesive enough to lift them. A little tapping with a ball hammer to crack the tiles and job done. :thumbright:
Marc, thats a lovely idea but for one flaw; the tile's only cover a section of the wall. I'll be tilling the whole wall...not sure how I'd explained a raised section in the middle. :scratch:
ashleywood.ash
good stuff :thumbright:
marc1106
Post by marc1106 »
gib_goblin wrote:Thanks Ashley, your idea works. I used a trowel to get under the edges and that 'cuts' the adhesive enough to lift them. A little tapping with a ball hammer to crack the tiles and job done. :thumbright:
well i couldnt see that from here! could i :lol: :lol: :lol:
Return to “Tiling Forum”
