Strengthening bolt holes
All Questions about Acrylic in here please.
Locked
brisa_main
Post by brisa_main »
Hi
I have some bolt holes drilled in some 10mm cast acrylic. When tightening one of them I heard and then saw a small crack running off from the hole.
It has to be done up pretty tight (maybe not as tight as i did) so is there anyway to strengthen a hole?
It was laser cut if that helps
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Re: Strengthening bolt holes
Post by kellys_eye »
All you can do is spread the load. Acrylic will have a certain load value at which point it breaks and spreading the load is the only way to increase it. Larger washers.
If the acrylic isn't meant to 'crush' together then you can sleeve the hole with a piece of metal pipe.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
It's easy to crack acrylic regardless of how the holes have been drilled.
As kellys_eye has said a metal insert in the hole will help prevent this.
If you are tapping the acrylic to accept a thread you are better off using a thread insert if you have to have the bolts tight.
brisa_main
Yeh i think metal inserts would work great. Good thinking!
Locked
Return to “Acrylic Forum”
