centre of room and squared
bgatty68
Has thanked: 21 times
Been thanked: 5 times
Post by bgatty68 »
can someone tell me if this is correct.
1. measure from one end of the room to the other to find the centre of the room but measure two points and join together with straight edge.
2. measure from the other way and two points again and then put a square on the first line and then join the other two marks up and then this should give me the centre of the room plus my lines will be square which will mean all layed tiles will be square and then all cuts at edge done as neccessary.
Is the above correct, please help :help: :wink:
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Re: centre of room and squared
Post by wine~o »
yes...but in addition loose lay one row of tile length and width of the room...then you'll have an idea of how the cuts will be at the walls..adjust accordingdly to make sure you don't get any small/fiddly cuts.
bgatty68
Post by bgatty68 »
Thanks Wine~o, so my way to square it up is correct :huray: will do on the dry laying thanks :thumbright: :wink:
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
No it isn't :roll:
That will give you a parallel line from the edge, but not necessarily square with the walls at the end of each line.
To do that you would need to apply the 2-3-4 rule.
bgatty68
Post by bgatty68 »
whats the 2-3-4 rule please scruff :cb im starting in the morning
Has thanked: 735 times
Been thanked: 2340 times
you go along 3unit then loosely at right angles 4 units then its 5 units diagonally makes a square
if you want to make a square you must work accurately if you use 3x1"par[69x22mm] draw a point centrally across the timber where they join these must be exactly 3 4 and 5 where the lines cross so have about 3"/75mm so you have a small overhang each end so the screw is away from the end where the lines cross
you can use any units you like inches feet metres or multiples off for example 15x20x25"
thescruff
Post by thescruff »
a 3 feet x 4 feet right angle will measure 5 feet across the diagonals
So if you mark 4ft from the wall along the center line, then 3ft along the wall, if it is 5ft from the two ends the wall is square with the line.
bgatty68
Post by bgatty68 »
scruff i think i got that, but if its not 5ft then what line do i move :dunno:
use multiples off inches or cms as in multiply the 3 4 and 5 by say 8 so 24x32 and the diagonal 40
the big one [5]is a diagonal between the 3 and 4 outer ends
bgatty68
Post by bgatty68 »
Big-All
sorry to be a pain, are you able to do a simple sketch and post it on here :oops:
wine~o
Post by wine~o »
Bit like this...
thescruff
Post by thescruff »
bgatty68 wrote:scruff i think i got that, but if its not 5ft then what line do i move :dunno:
You move the line in or out until it is, to get the perfect square.
You may find centralizing the tile both directions and cutting the edge tiles to fit will be the best plan, as it's very unlikely to be square all round.
Lay a dummy run along the line the full length of the room.
Return to “Tiling Forum”
