Can I Seal Concrete Kitchen Floor With.....
Webby Bear
Has thanked: 7 times
Been thanked: 2 times
Post by Webby Bear »
..... hi guys
just got up my old lino and got up as much glue as possible. theres still some glue that just wont shift. am i right in thinking i can simply seal the floor now with BAL Primer straight over the old glue?
i promise you it just wont budge and ive been told i should just prime straight over it. can you tell me thats correct/?
cheers
marc1106
Has thanked: 4 times
Been thanked: 49 times
Re: Can I Seal Concrete Kitchen Floor With.....
Post by marc1106 »
have you tried a sharp bladed scraper? is it lumps or just residue? and how much is left % wise?
IF IT WERE EASY ITD B BORING!
Webby Bear
hi mate - yeah im using a sharp scraper and a chisel which has woeked so easy to get the stuff up. thers absolutely no lumps. its just the residue and everythinmg is completely flat. id say thres a thin kind of layer over most of the floor but since the floor has been up its actually seemed to have dried :) :)
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Are you going to use the normal BAL primer or SBR?
marc1106
Post by marc1106 »
id go with the SBR !
Webby Bear
was gonne go with the BAL primer as suggested :)
fipple
Has thanked: 1 time
Post by fipple »
check the level of your floor also(dips.bumps )...may need self levelling!
Return to “Tiling Forum”
