Childrens play area
Childrens play area
Hi
I'm looking to build an area in our garden for swing/slide to sit on. Basically want to build a wooden frame to partially sink into the grass to make a level surface and then fill with rubber bark to provide a cushion should they fall.
Is there a specific treated wood that would be best for this use? I assume any wood, however well treated will rot over time, so something to prolong the life is what I need.
Thanks.
Thanks.
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Hi Hutters,
Your best bet will probably be tanalized timber, this has been treated under pressure and will last much longer for external use.
Partially burying it will mean that it will eventually still rot, but will last much longer than non treated timber.
Railway sleepers will last a long time, but they are covered in tar, which may come off onto clothes etc.
The only solution to prevent the timber from rotting would be to raise it up slightly to allow air to circulate, but if you use tanalized timber it will probably be 5 years or more before it rots really badly.
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
yep i agree entirly with uhm
just though i would throw this in the mix as it is flexible and will allow nicer shapes
http://www.everedge.co.uk/home.htm
dont know anything about the product i just like the fluid possibilitys
- ultimatehandyman
- Site Admin
That is a good ideabig-all wrote:yep i agree entirly with uhm
I was trying to think of something made of plastic, but couldn't!
- carhartt kid
- Has thanked: 3 times
- Been thanked: 1 time
Funnily enough I went into Wickes today and noticed they had sleepers that were reduced by 70% today.
It might be worth a look, this was in Farnborough, Hampshire. I've no idea if this offer is throughout the UK.
http://www.wickes.co.uk/invt/187785
