Normally I use a blunt HSS metal drill bit for drilling acrylic, but today I could not be bothered getting them out of the van and so I tried the Bosch Multi-construction bits and they worked perfectly. You have to be careful when exiting the hole with a metal bit as you can easily chip the acrylic, but the Multi-construction bits went through no problems at all!
I'll certainly use them next time I need to drill any acrylic
Drilling acrylic
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Re: Drilling acrylic
I always thought it was 'proper' to drill from both sides to avoid chipping acrylic
- ultimatehandyman
- Site Admin
No, you don't have to.
You can normally go straight through from one side as long as you are not forcing the drill.
