Hmmm... need to get a duct through a floor? hack away !
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
Chris the builder
Has thanked: 10 times
Been thanked: 22 times
Post by Chris the builder »
Took down a garage ceiling (part of a convo) & found this beauty... from the looks of it the "heating engineer" would stop at nothing to run his flue, even removing a supporting floor joist to the underside of the bathroom!
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Re: Hmmm... need to get a duct through a floor? hack away !
Post by thescruff »
A big flue like that has regs to follow, how else would you suggest he installed it, assuming he cut the joists in the first place. :roll:
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Good point Scruff, I'm sure the joist was already randomly cut away at 45 degrees :lol:
Chris the builder
Scruff, I sincerely & respectfully ask that you stop following my posts, you are the one person who makes visiting this brilliant website tiresome, my friends call it "being anal".
You are defending a cowboy who has lobbed off a flooring joist without any attempt at supporting it thereafter, also leaving a loom of cables lying across a hot metallic duct. Regs to follow? are you joking? how about this one "try to do your job without killing someone after your done" how else would I suggest he installed it? is that what you would say to a concerned customer? that is the worst reply I have ever heard in a long long time lol.
:lol:
thescruff
Post by thescruff »
Did you see the plumber cut the joist, perhaps the cowboy builder did it when it was built/converted.
The cables were off the pipe, it's only the bell wire or phone, and who knows at what stage that was put in.
I would guess there's no weight in that corner anyway, as I bet a pound to a penny there's a great big box in the corner, perhaps the joist has been fixed to the wall, you can't see in one pic.
Get used to it, the mods check every post, and stop assuming unless you were there and saw who did what.
Razor
Post by Razor »
Come on chaps, chill out and enjoy yourselves there's no need for anyone to make silly comments :wink:
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 343 times
Post by Gadget »
Pistols at dawn?... :lol:
By eck! ©
thescruff
Post by thescruff »
So you have third party information that the plumber did it, and decided to slag whoever it was off.
Ok it's sh*t and not right but any jack could have done it.
Assuming it isn't how much trouble would it be to chemically fix that first joist to the wall.
And since we're on the subject, the second joist has been taken out and replaced, was that the plumber as well. :roll:
I love UHM & told my workmates about it, it's great but you are spoiling things.
Get your facts right. simple
Razor
Post by Razor »
Scruff as I don't have anything to do with that type of flue can you tell me if it's twin wall and what the clearance to combustible materials should be (25mm?) I presume it's going to need a plate around it where it goes through the ceiling?
I'd agree the joist needs chemically studding back to the thermolites.
Of course knowing how lazy heating engineers are it's quite possible the builder hacked the joist away after they told him what clearance they needed :roll:
thescruff
Post by thescruff »
Yes it should have a plate on it with a 25mm air gap.
Can't see the end of the flue where it goes through the floor or out the wall. looks as though it goes into a single skin. :shock:
But it would need 600mm vertical pipe (I think) off the boiler and then 45% bends. post the boiler make and model and I'll tell you.
Not that it makes any difference but it looks like 6" selkirk twin wall.
Gadget
Jack Of All Trades
Post by Gadget »
It seems we may have lost a first class contributor to the forum, Chris has removed his avatar!
By eck! ©
martyn1967
Has thanked: 2 times
Been thanked: 26 times
Post by martyn1967 »
Sounds a bit like Somebodys thrown teddy out of cot!!! :B
What would you rather bee or a wasp!
Gadget
Jack Of All Trades
Post by Gadget »
martyn1967 wrote:Sounds a bit like Somebodys thrown teddy out of cot!!! :B
Thats b*llox, the man was making valid comments, but he was shouted down by someone trying to justify cowboy antics!
By eck! ©
thescruff
Post by thescruff »
No-one trying to justify cowboy antic Gadget.
It could have been the heating guy, a specialist flue Company, the builder or the bloody gardener for all know. ::b
diyguys
Has thanked: 178 times
Been thanked: 19 times
Post by diyguys »
What would the gardener be doing fitting a flue lol
Return to “Rogues Gallery”
