where to buy wood board
- Has thanked: 823 times
- Been thanked: 3560 times
You would have to join a number of boards of solid timber to make a table top. This is not easy to do unless you have a number of tools to help you do it. Why not use wood veneered board to make it instead. Have a look here http://www.silverman.co.uk/index.php
- BANNED
- Been thanked: 1 time
wickes sell pine furniture board
http://www.wickes.co.uk/invt/110159?htx ... NXrg%3D%3D
you could stain it to look like most woods
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
i have used the the timberboard quite a few times in the past its realy good although it was 18mm not 28 as suggested
another way to make simmilar size is to make a frame from 2x1" par[planed ]18x44mm rebate out [12x12mm]and insert 12mm ply with the best side up and grain running across the desk
- Has thanked: 77 times
- Been thanked: 335 times
Wickes do a limited range of the 'Timberboard', but a little cheaper.
BnQ do a wider range, but a little dearer.
Most sixes are 18mm thick, but larger sizes are also in 28mm i think (in Wickes anyway.)
Also known as Premboard.
If you go down this route, select the pieces carefully, a few seem to have very big knots or resin pockets. (especially the Premboard)
