ceiling rose?
Posted: Sun Apr 09, 2006 7:57 pm
by kidd
Help, i am replacing a light fitting and i am now confused.
I have a earth, a black sleeved wire, a red sleeved wire and a grey sleeved wire, these are to go to a 2 gang choc bock with a blue and brown wire to the fitting. can any one advise on which wires go where????
Posted: Sun Apr 09, 2006 8:59 pm
by markysparky
If you can give some indication of where they were before I might be able to help :shock:
Or post a photo if you can?
Posted: Sun Apr 09, 2006 9:02 pm
by tim'll fix it
lighting circuits have
earth - green/yellow
live - red or brown these days
neutral - black or blue
and
switched live - supposed to be red - brown.
However the colours are often mixed up due to the lack of cores. You will need to connect the
switched live - to the brown of the fitting
neutral to the blue of the fitting
earth to an earth point if provided or in a connector block if not
and connect any permanent lives together in a connector.
can you post a picture of what you have
pls note I'm not a spark but have fitted countless lights.
Posted: Sun Apr 09, 2006 10:22 pm
by kidd
Sorry but dont no how to post pics on here. I have managed to get the light working but have a red wire and the earth still not connected to anything? so shall i connect these to seperate connectors,
thanks
ian[/img]
Posted: Sun Apr 09, 2006 10:33 pm
by markysparky
Connect the earth to the rest of them.
The red wire could be a feed for either the switch or another light!
Does the switch turn the light on and off ok?
Are there any other lights in the house not working?
Posted: Sun Apr 09, 2006 10:38 pm
by kidd
Everything else works in the house, The new light fitting only came with a 2 gang block aaand so have no where to put these remaining 2 wires? and yes the two switches that use this light both work fine??
