Tiling down to shower tray...
blakes
Has thanked: 6 times
Been thanked: 9 times
Post by blakes »
Going from an earlier post which made me aware of tile 'movement' am I right in assuming that when tiling down to the shower tray, the tiles don't want to be in contact with the tray i.e sit them on a 3mm spacer and then when I've finished, use silicone to seal?
Thanks in advance.
Has thanked: 735 times
Been thanked: 2340 times
Re: Tiling down to shower tray...
mark the wall 1 tile +4mm above the tray[more iff not self spacing] secure a batton on the line
remember to silicon the tray to the wall before tiling down an siliconing again
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
big-all wrote:mark the wall 1 tile +4mm above the tray[more iff not self spacing] secure a batton on the line
if using battons in a wet area...be carefull you dont peirce the tanking(IF USING THESE).. when your using batton etc...or all bets are OFF...(mfr instructions)...
Return to “Tiling Forum”
