Drill/driver confusion
leaf
Post by leaf »
I'm know there are plenty of posts regarding the ever popular topicof drill drivers but i am totally confused by them all.
I have a corded drill for heavier stuff like drilling into walls, but i'm fed up with having to use an extension cord whenever i need to put up a picture or getting blisters from tough screwdriving. So basically, all i'm after is a good drill/driver for odd jobs round the house and in the garden.
Having read a few comments about needing lighter tools for those overhead jobs (curtain rails, lighting, etc.), i can see the benefit of Li-ion batteries but i really didn't want to spend much over the 50 quid mark.
I've seen a 14.4v model in Homebase made by Works for about 50 quid but i'm dubious as to whether this is an own brand, and after hearing of the poor quality of B&Q own brand tools, i'd rather not waste money on going for the cheap option.
Any advice will be greatly appreciated and thanks in advance.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Hi Leaf,
welcome to the forum.
Higher voltage drills are normall heavier than the lower voltage counterparts, but have less power.
The cheaper drill/drivers normally take a few hours for the batteries to charge and they normally do not last long from one charge.
This is a cheap one- http://www.screwfix.com/app/sfd/cat/pro ... 2&ts=30789
This is a mid priced one that will last a bit longer then the one above- http://www.screwfix.com/app/sfd/cat/pro ... 9&ts=30896
and this is a better one- http://www.screwfix.com/app/sfd/cat/pro ... 6&ts=30975
The hitachi will last you a few years, the erbauer a few months and the really cheap one a few months.
You do get a guarantee with them all though and so if it breaks you can send it back.
The choice is yours!
If you can wait 3-5 hours for the battery to charge then the first drill is a bargain, although there will be p&p on top.
You could always buy two of them and keep one for spares, then you would have 2 batteries.
Personally I would get the Hithachi, but it is a little dearer!
Hope this helps a little :wink:
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
For £50 you wont get lithium ion.
But if your only diying, a few holes every few weeks, weight shouldnt be much of a problem.
Any 14.4v should be capable of drilling a wall, but make it easy for yourself- buy a good set or drills- these are good in corless drills.
http://www.screwfix.com/app/sfd/cat/pro ... 9&id=88598
If its only going to come out once a month, go down the erbauer route, any more, go for the hitachi.
If you leave it for weeks at a time in between use, be prepared to charge the batteries before use, especially on cheaper tools.
honeymonster
Post by honeymonster »
Ryobi are pretty good and it will be much better then any of the home made brands from the sheds as many of these are poorly made.
Return to “Tool Talk”
