5 lever mortice sashlock
- jackster
Hello,
I am having problems with the lock on the front door, it is a 5 lever mortice sashlock. It is becoming more and more difficult to lock and unlock, I have 3 keys and one particular key will open the door from both sides but will only lock the door from one side!
Sometimes it takes lots of jiggling with the key to get the door to lock or unlock.
If I remove the lock is it possible to take it apart and service/clean inside or is it best to purchase a new lock? I have tried oiling it with some WD40 but with no success.
- BANNED
- Been thanked: 1 time
take the lock out of the rebate and measure the depth it will tell you if it is 2 1/2" or 3", or measure the distance from the door edge to the key hole, which will tell you what type, if it is about 44mm then it is a 2 1/2" (I think).jackster wrote:Hi, I just squirted some oil in the keyhole.
I am due to replace it asap, not sure if it is a 2.5 inch or 3 inch, so will probably get one of each from the ironmongers, then take back the one that I do not use!
Thanks for the replies
- Wood Magnet
- Been thanked: 3 times
- jackster
Took me a little longer than anticipated as the new lock was slightly thicker then the old one and the face plate was also thicker. After a few minutes ( about 45 ) with the wood chisels and hammer it fit perfectlypitbull wrote:So how did you get on jackster.
As mentioned in previous posts it could of cost me dearly if it had siezed shut
I'm was thinking of getting a joiner from here -
Carpenter nottingham
- dirtydeeds
- Craftsman Carpenter
For about £25 you buy a new set of levers, rather than a new 5 lever lock at £50 (its called going to a proper locksmith)
split the lock body, change the levers, job done
I earned £90 three weeks ago doing it, i paid for additional keys and a follower as well in the figure
knowledge is how to make money
- Gadget
- Jack Of All Trades
- Has thanked: 344 times
- Been thanked: 342 times
£50 for a 5 lever lock!!.....where from, Harrods?........I get ERA 5 lever for £15-£20 at my local merchant!!dirtydeeds wrote:For about £25 you buy a new set of levers, rather than a new 5 lever lock at £50 (its called going to a proper locksmith)
By eck! ©
- dirtydeeds
- dirtydeeds
