Unscrupulous Leadwork!
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
martyn1967
Has thanked: 2 times
Been thanked: 26 times
Post by martyn1967 »
This lead flashing looks to have been replaced within the last few years , they have chased it into the brickwork upto 2/3rds of the way up & then i think they must have got stalled & nailed the last 1/3rd with clouts!
Roy Rogers & Trigger me thinks. :scratch:
flash2 (Small).jpg (39.9 KiB) Viewed 8031 times
flash1 (Small).jpg (39.3 KiB) Viewed 8031 times
flash (Small).jpg (44.94 KiB) Viewed 8031 times
What would you rather bee or a wasp!
Has thanked: 1012 times
Been thanked: 918 times
Re: Unscrupulous Leadwork!
Post by ultimatehandyman »
Classic :lol:
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Looks like marine cable that hasn't got enough clips along its length too.
Seems strange to do a job well and then give up............seems a classic case of Rogue client and the roofer got his own back.
coventrycraig
Post by coventrycraig »
that looks terrible - why so many pieces of lead.
im only self taught and realise that its not that hard to.
craig :shock:
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 344 times
Post by Gadget »
Thats terrible, should've used copper nails!!.. :lol:
By eck! ©
coventrycraig
flashband will lasy for years :huray:
craig
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
royaloakcarpentry wrote:Looks like marine cable that hasn't got enough clips along its length too.
I thought that was a hand rail Oak :lol:
I'm not going to comment on the lead. :B
royaloakcarpentry
Dunno mate, I wasn't a mountain leader lol.
martyn1967
I think the same roc & luckily for me I didnt get the job of strip & recover :huray:
martyn1967
4 got to say :dunno: is it marine cable? my spark says its 4mm armoured 3 core & apologized about it not being the right colour. :?
I'm not sure what marine cable is, so it might just be another name for it.
That cable looks like SY Multi flex (flexible armoured cable), we use it quite a bit at our place for connecting to machines that move.
martyn1967
Yes chas. im pretty sure he called it sy, & said to use it as its very flexible & would be user freindly for the Obstacle course it had to get over to get to consumer unit.
Like scruff says, it is a bit handrail,ish.. :lol:
royaloakcarpentry
SY is what we used to call marine cable........clear outer sheaf then armoured. Have only used it for air conditioning as it was on the spec. It is control cable.
sparkydude
Been thanked: 149 times
Post by sparkydude »
SY flex, Great for machines , and temporary jobs, Crap for permanent installs as after a few years in the sun, the outer clear sheath goes opaque and then eventually becomes brittle and falls off. Personally i would have used it for the tricky house bit a then changed to SWA for the exterior part as the black sheath does not suffer from UV radiation as much as the SY flex.
Nick
martyn1967
sparkydude wrote:SY flex, Great for machines , and temporary jobs, Crap for permanent installs as after a few years in the sun, the outer clear sheath goes opaque and then eventually becomes brittle and falls off. Personally i would have used it for the tricky house bit a then changed to SWA for the exterior part as the black sheath does not suffer from UV radiation as much as the SY flex.
Nick
SUN.. where?.. We are in England.
Cheers for advice nick , my spark is ex services & probably got better knowledge on wiring nuke submarines! but hes a great guy & (nappin, nice, registered etc :lol: :lol: )
On a serious note he carrys out his work for a fair price thats ticketed
Return to “Rogues Gallery”
