Hi all,
I recently installed kitchen cupboards, I mitred the cornice for the bottom of the unit, and it was fine, however when I went to screw it on I noticed that when I brought the two bits together the cornicing at the back of the unit wasn't in line with the front of the unit. (I hope this makes sense?). I again made another cut but the same problem occured. Any ideas as to why this happened.
I used a mitre compound saw at exactly 45 Degrees
I have mitred plenty of other materials with no problems. Can't understand why this happened.
Any advice would be appreciated
Kitchen cornice
- Has thanked: 7 times
- Been thanked: 21 times
