External Lighting under soffits
Locked
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
Would like to put some lighting under the soffits. They wouldn't suffer direct weather/weathering but will be exposed to the outside.
Recommendations?
12v?
Any precautions or things to be aware of.
Jaeger.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
I'd get led ones to be honest and then you do not have to worry about changing the lamps when they go!
12v would be my choice.
I just fitted an extractor fan and vented it out of the soffit, be careful when drilling the holes with a hole saw as they can grab and if you are working at heights it is not a good idea. A scaffold tower is recommended rather than a ladder. I just leant out of the bathroom window!
Jaeger_S2k
Pro Handyman
Are you thinking of something like this?
Haven't seen these in operation except in my head light, which is great for working under, white and never runs out.
http://www.qvsdirect.com/5-Fittings-Cei ... 21683.html
They're tiny
Have found a new wholesaler who seams reasonable will call in and see what they've got.
Jaeger.
Locked
Return to “Lighting”
