backing plaster
Quest
Has thanked: 11 times
backing plaster
Post by Quest »
whats the best thing to apply to bonding and hardwall undercoat plaster before tiling apart from a multifinish top coat skim as i have heard adhesive cant go straight onto this surface? is there a primer or pva of some sort?
rjwtiling
Re: backing plaster
Post by rjwtiling »
bonding or hardwall is not a suitable surface to tile onto imo
skim the walls 1st then prime . i.e mapei primer g
what size tile are you using .as there could be a weight issue , depending on size of tile and what material they are
i.e porcelain
m3 fitter
Tiling Expert
Has thanked: 7 times
Been thanked: 14 times
Re: backing plaster
Post by m3 fitter »
don't use PVA :sad: ( use the search facility to find out why ) use an acryllic primer, with large format tiles,use a powder based single part or rapid set adhersive
Return to “Tiling Forum”
