The gates are hanging
mcluma
Has thanked: 5 times
Been thanked: 26 times
Post by mcluma »
This weekend, I found some time to weld the shoe to the bottom hinge, the shoe is a 1 ½ foot long piece of U profile that will fit around the bottom joist of the gate
The hinge above is the wall plate which is going to be the top hinge
I admit I am not the world’s best welder, but was not disappointed with the final result (of course I ran out of welding wire, and had to get some new one, (I just got a bit crazy and didn’t now I was using that much wire)
Below you see the shoe fitted to the bottom of the gate, 6 screws will hold the gate in the shoe, the bottom got painted before fitting
Here you see the final result of all the hard work, the gates are finally fitted
This is the back of the gate with only one coat of paint on
AND THE FRONT
Really happy with the final result, the opening between the gates is 12mm, i had calculated for 10mm, so all in all really happy
What remains to be done is:
Electrics / Intercom / lights / wooden gate styles / etc
Has thanked: 734 times
Been thanked: 2336 times
Re: The gates are hanging
absolutely brilliant job :thumbright: :thumbright:
bet your pleased :salute:
although if that's exposed un-painted wood on the bottom your in trouble especially if its covered by metal :? :? :roll:
mcluma
Post by mcluma »
No its not, its been treated with the sadaline stain, the whole gate has been done now three times, we probably will redo it again when its a bit warmer, as this stuff dries so slowly
northwales4u
Has thanked: 76 times
Been thanked: 151 times
Contact:
Post by northwales4u »
wow - they look brilliant
Cant tell from the photo's if the post box is on the inside of the property or out (just thinking of Mr Postie having to open them up each day to deliver your junk leaflets)
Mike
mcluma
Post by mcluma »
northwales4u wrote:wow - they look brilliant
gates open inwards, so you can drive up (have the car of the main road) press the intercom
Mailbox opens up at the back, so we can get at it without having to open up the gate
mcluma wrote:No its not, its been treated with the sadaline stain, the whole gate has been done now three times, we probably will redo it again when its a bit warmer, as this stuff dries so slowly
fantastic would hate for you to get caught out after such a brilliant job :huray: :huray: :thumbright:
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
ive been folowing this on ukw :thumbright: top work
wine~o
Has thanked: 1414 times
Been thanked: 4015 times
Post by wine~o »
speed wrote:ive been folowing this on ukw :thumbright: top work
:dunno: Ukw???
speed
Post by speed »
uk workshop , co.uk
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Nice job.
Fully welded, no wonder you ran out ;)
What machine are you running?
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Good use of the floor box and shoe to hang them. They blend in well with the situation. Very nice work.
Just observations and nothing to do with your workmanship:
Surprising that such big gates and obviously not cheap are not manufactured from joinery grade timber, as standard. At least the Sadolin will allow the resin from the knots to bleed through and be wiped away by the client for a year or so until they have stopped bleeding. I wonder how many edge knots are going to be popping out.
With gates that size I would expect the braces to be let into the ledges. ledges should also be chamfered. You can also get them with a drip groove to the underside of the ledges but would probably be bespoke for that.
EddieJ
Has thanked: 21 times
Been thanked: 20 times
Post by EddieJ »
royaloakcarpentry wrote:Good use of the floor box and shoe to hang them. They blend in well with the situation. Very nice work.
You forgot to mention not having any rebate on the centre closer. :wink:
royaloakcarpentry
I did clock that these are not rebated gates and the viewing gaps up each side. Then again I also considered not posting the extra bits for members info, as these are off the shelf gates and not bespoke ones. Well, I would hope they aren't bespoke.
On the other hand, the house doesn't seem to be in more secluded spot, rather than having loads of commuters walking past and peering through gaps as they do so. So non rebates aren't so much of an issue.
Still nice workmanship for the job though.
mcluma
Post by mcluma »
royaloakcarpentry wrote:I did clock that these are not rebated gates and the viewing gaps up each side. Then again I also considered not posting the extra bits for members info, as these are off the shelf gates and not bespoke ones. Well, I would hope they aren't bespoke.
There are still styles to be fitted at the collums, and also a centre strip/style, you always have one lead door, so when everything is done, you are not able to peak through anymore.
They are semi bespoke / of the shelf. i give them the measurements / model type, and they build according to it
With all gates, the proof is in the pudding, lets see how they are in a year or so, have the sagged, split have knots popped out (although its grade 5)
mcluma
Post by mcluma »
Hitch wrote:Nice job.
I have a clark MIG 151 EN
I got the welder from my BIL as he never uses it, and had i burried in his shed.
I bought 3 years ago one of those electric visors that go dark when there is a spark, and they are brilliant.
Return to “Show Case Gallery”
