Oven and Fridge Freezer
Locked
sarcy
Post by sarcy »
Just after some advice really, looking into fitting a very small kitchen soon. Still at the planning stage at the moment, basically wanting to know if its ok to have a built under single oven with a small unit between either 150mm or 200mm and then a freestanding fridge freezer? I have read that its not adviceable to have a fridge freezer next to an oven, i wonder if this small unit will be sufficient seperation? as this seems to be the only way we can make everything fit.
Thanks in advance for your advice!
Has thanked: 823 times
Been thanked: 3559 times
Re: Oven and Fridge Freezer
The sidewalls of fitted ovens give off little heat so I would not be concerned. It is more important to have a clear airflow at the back of the fridge freezer to allow the heat generated to dissipate.
Locked
Return to “Kitchen Fitting”
