tensol 70
Posted: Sun Sep 09, 2007 3:56 pm
by martek man
Hi
As anyone any advice on mixing Tensol 70, there is 2 parts, resin & hardener but i`m unable to find any instructions regarding quantity to use
Posted: Sun Sep 09, 2007 4:05 pm
by ultimatehandyman
It comes in two containers that are the correct quantity for one mix and so you mix the whole contents of both together and this will give you the correct ratio. But you then have to use the full amount or else it will harden!
From the size of the containers that you have you can work out how much to mix if you do not want to use it all at once.
So for example if one container contains 500ml and the other one 100ml then you could mix 100ml from the first container with 20ml from the second container etc.
