Suitable for Tiling ?
newdud
Has thanked: 40 times
Post by newdud »
I am re-decorating my bathroom at the moment.
I have removed the tiles from the wall (they were put on around the mid 80s)
The tile adhesive has been removed using a wall paper steamer and a scarper.
The walls are brzze block with a 1/2 inch plaster on it.
Looking at the attached picture you can see some of the top coating of the plaster has come off and there are some traces of the old adhesive left. I intend to fill in the 'holes' with new plaster.
Can I put new tile on them now or do I have to do some more preparation work. :dunno:
I intend to use average size ceramic wall tiles.
Julian Cassell
Has thanked: 11 times
Been thanked: 55 times
Re: Suitable for Tiling ?
Post by Julian Cassell »
Hi there,
The flatter the surface, the easier it is to tile. If it was me, I'd get it skimmed. You could patch and sand it down - but is it worth the time and effort, and it still won't be as good as a skim?
Sorry, probably the answer you didn't want to here.....
mcluma
Has thanked: 5 times
Been thanked: 26 times
Post by mcluma »
another vote for reskimming
you cannot beat a flat wall when tiling
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
just buy a bag of BAL quickset render, then prime the wall with apd primer, and allow to dry before you apply the quickrend, follow the MIs on both products and youll be ok! then tile away!
These users thanked the author marc1106 for the post:
newdud
IF IT WERE EASY ITD B BORING!
newdud
Post by newdud »
The Wall is reasonable flat even though the picture does not show it. :wink:
Thanks to every one that made suggestions, I will take it under advisement. :thumbleft:
Return to “Tiling Forum”
