Bosch PMF 180 E
Posted: Sun Mar 06, 2011 8:14 pm
by glossy
Has anyone found that when using this multi-tool by Bosch that the screw that holds blades has a tendency to work loose when being used? If so have you any solutions apart from the obvious one tightening the screw. Many thanks.
glossy
Re: Bosch PMF 180 E
Posted: Sun Mar 06, 2011 9:40 pm
by dave.m
Don't have the problem, but you could try a spring locking washer. It would allow you to unscrew to change the tool but would possibly keep the retaining screw locked during use.
dave
Re: Bosch PMF 180 E
by Inky Pete
Never had it come loose on either of the 2 I've owned.
Re: Bosch PMF 180 E
Posted: Mon Mar 07, 2011 6:49 am
by polishingpeanuts
Me neither and I have hundreds of days up, using mine. Granted though, they are a 'buzzy' little machine, so the bolt working loose isn't impossible!
