Hey guys, hope someone might be able to help or advise what's best to do..
in our bathroom, there's a patch of damp/mould that started off in the corner of the ceiling and has been slowly growing over time and looks considerably worse now. It's a patchy blackish-grey colour and rubs off slightly when you touch it like charcoal kind of.
The room is ventilated by a small window only, and with the heating being off most of the summer, I wondered if this couldve contributed to it allowing it to get damp?
I'd be really grateful if anyone could help with a short term fix or suggest how to help prevent it long term?
cheers
Damp/mould problem in bathroom
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
Investigate the cause and eliminate the obvious.
Up stairs (I assume loft space) locate the corner inspect any pipes and the roof members. Check pipes for green residue or wet marks. Check the roof immediately above but also check the roof members as the leak may be somewhere else and the water is using them as a capillary and dropping.
If there's nothing evident then could be ventilation problem. Lots of rooms are vented from small windows but they have to open to work
Installing an automatic timed vent would help but that can be annoying in the night.
If you have a shower then an extractor would be a valuable addition and should be used when the shower is used or a steamy bath is run.
Jaeger.
- Has thanked: 814 times
- Been thanked: 3508 times
Clean with a bleach solution to kill off the mold spores. When dry spray with stain stop to seal it and repaint using a silk emulsion. It is steam wetting the ceiling that has provided the hospitable environment for the mold to develop so you need to address ventilation. As Alan has said you need to get an extractor in there.
- Has thanked: 3 times
- Been thanked: 31 times
Hi mg1prg,
As jaeger has said rule out leaking pipes or water ingress from above, but 99% of the time it is down to ventilation installing a good quality extractor fan such as expelair or vent axia will usually sort the problem, i had a shower room with no windows and i did fit a 150mm timed fan that had an overun of about 8mins and we had no damp issues at all but our original bathroom had a large window and no extraction and this eventually succumbed to damp patches until an extractor fan was fitted.
Personally if you go down the route of extrator fans i would fit a 150mm size fan as the small 100mm are not as effective.
Hope this helps
Hope this helps
