Undermount Ceramic Sinks
Locked
ChrisfooDIY
Has thanked: 1 time
Post by ChrisfooDIY »
I'm soon going to be fitting undermount ceramic sinks to solid oak worktops which is something I've not done before. Can anyone offer any guidance on the correct way to do this. I have an idea, but want to see what the experts suggest.
Thanks,
Chris.
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Undermount Ceramic Sinks
Post by royaloakcarpentry »
What thickness worktop.....got a link for the sink type?
ChrisfooDIY
Has thanked: 1 time
royaloakcarpentry
What was the idea that you had for under mounting these??
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
you need to fit a shelf for it to sit on but make sure it will support the weight some of those sinks are 30 kgs before you add 10kg of water! then cut your cutout making it 10mm smaller than the bowl so you can rout a V grove as a drip edge underneath! hope this helps! :thumbleft:
These users thanked the author marc1106 for the post:
ChrisfooDIY
IF IT WERE EASY ITD B BORING!
ChrisfooDIY
Has thanked: 1 time
marc1106 wrote:you need to fit a shelf for it to sit on but make sure it will support the weight some of those sinks are 30 kgs before you add 10kg of water! then cut your cutout making it 10mm smaller than the bowl so you can rout a V grove as a drip edge underneath! hope this helps! :thumbleft:
Nice one. Not the idea I had in mind, but this sounds much simpler. Ta very much.
Has thanked: 736 times
Been thanked: 2341 times
exactly as mark but make sure your grooves underneath start and finish within the sink or if you accidentily go to far fill with silicon
royaloakcarpentry
Bugger it, I wanted to know what his idea was lol.
joinerjohn
Has thanked: 17 times
Been thanked: 315 times
Post by joinerjohn »
A friend is soon having a new kitchen fitted and is apparently having an undermount sink in a granite top. For some silly reason, he thinks he can buy the undermount sink, after the granite worktops have been installed. ::b ::b ::b
marc1106
Post by marc1106 »
joinerjohn wrote:A friend is soon having a new kitchen fitted and is apparently having an undermount sink in a granite top. For some silly reason, he thinks he can buy the undermount sink, after the granite worktops have been installed. ::b ::b ::b
:lol: :lol: :lol: how does he think theyll template the granite?
Locked
Return to “Kitchen Fitting”
