tile on plaster board ?
Posted: Wed Mar 16, 2011 11:09 pm
by paul777
hello
i`m thinking of tileing my bathroom out in a few months
the old black moter is on the walls
knocking all off to the brickwork
then drylining the wall with 12.5 plaster boards
is this suitable to tile on the boards
thank you paul
ps i will not be plastering the wall
Re: tile on plaster board ?
Posted: Thu Mar 17, 2011 8:06 pm
by royaloakcarpentry
It is suitable for tiling on.
Like any substrate though, you need to keep within the limitations of combined weight it can take.........combined weight being, adhesive, tiles and grout.
Posted: Thu Mar 17, 2011 8:35 pm
by marc1106
12.5 mm PB is about 30kgs per meter but as ROC says this must be tile, addy and grout! general rule of thumb is 4kgs per mtr for addy and grout!
the exact weights can be found in the white book by BG
Posted: Fri Mar 18, 2011 11:36 am
by paul777
thank you guys
but what if i put a lot more dabbing of adhesive on the walls ?
and use plaster boards with Polystyrene backing ?
or batten the walls and screw plaster boards ?
i realy need to know if i can tile on plaster boards safely
thank you paul
Posted: Fri Mar 18, 2011 12:27 pm
by dewaltdisney
I would advise that you use Aquapanel or similar cement board in the wet areas. Any water creeping through a pinhole in the grout will knacker the plasterboard substrate. http://www.knaufdrywall.co.uk/aquapanel/ You cannot dot and dab Aquapanel see http://www.teachmediy.co.uk/NetsiteCMS/ ... panel.html
Posted: Fri Mar 18, 2011 6:45 pm
by marc1106
paul777 wrote:thank you guys
you shouldnt be dabbing tile adhesive, it is applied in a thin spread then combed up! doing it that way keeps the weight to 3-4 kg per meter!
if you use insulated plasterboard this shoud be mechanically fixed as well as dot and dabbed!
if you batten then use a kingspan insulation then use hardi backerboard as that hold 50kg per meter of tile!
you can tile straight onto plasterboard as long as your tiles and adhesive and grout DO NOT EXCEED 30KG per meter
just remember your tiling is only safe as long as the substrate is secure fixed!
thank you paul
your welcome! :thumbleft:
