Hi, Having lifted the carpet in my hallway I discovered old Quarry tiles. They seem in good condition and I'm sure they are layed directly on earth. I want to clean them up and re grout where needed. Also will I need to seal the tiles as I've read that because the tiles are layed on earth you don't seal? What type of grout is required?
Craig.
Restoring Quarry tiles
- Tiling Expert
- Has thanked: 7 times
- Been thanked: 14 times
Re: Restoring Quarry tiles
here's the cleaner http://www.extensive.co.uk/product.php/ ... cleaner-1l and also other products you may require, sand based grout are perfect for quarries, like Ardex c2, or any wide joint floor grout. hope it helps
