How to make and fit window boards?
Hi. I need to fit some window boards having removed all of the old ones and plaster boarded and skimmed the reveals.
2 questions. Firstly, how best to stick them so that I dont see screw heads if I decide to stain them? I did hear one guy on this site used expanding foam and plonked some heavy weights on the board while it set off but I don't know if that is best practice?
Secondly, most window boards I have seen appear to extend beyond the window opening by 4 inches or so at each end. Should I therefore cut my my boards 8" longer than I need and then notch out?
Grateful for any advice. Thanks
- Has thanked: 3 times
- Been thanked: 31 times
Hi Edz,
Most window boards are fitted before plastering as the plaster helps to hold them in place aswell as mechanical fixing, i have seen expanding foam used to fix window boards but i would,nt recommend it, i would definately screw them down and fill the countersunks with a good quality matching filler.
Yes you will have to cut your boards longer and notch them out for the extension length is down to personnal preferrance
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
assuming you are using solid wood
your boards should be glued together in sections alternating cup up cup down[wood grain]
so if your boards need to be say 11" inches deep you can make from 3+4" boards with only the last board needs to be full width
note that 4"planed boards will finnish up at around 11"[3x94mm]
assuming you have a surface to work to no nails or silicone would be my choice
- big-all
- Pro Carpenter
Is cupping where they warp and curl up?
I take that best practice is to take a plank, slice it into 3 or 4 lengths, then reverse the direction alternately and glue back together. Have I got it right?
If that is the case, do I need to dowel them too as well as using glue?
Also what glue would you recommend? Cheers
- big-all
- Pro Carpenter
cupping --middle raised compaired to edges --"curling" yes good explination
twisting --propeller shaped
bow ------bent like a cross bow or bannana
shakes---been struck by lightning or felled badly causing splits /diconnected fibres that are only often apparent when wood is worked
- Has thanked: 823 times
- Been thanked: 3560 times
Ski,
Cupping is the tendency for the wood to curl in the direction of the annular rings. As Big All has said alternating the rings of each board when jointing helps to level out the tensions. Another thing that you can do is run a shallow saw cut along the backs as this releases a lot of the tension that can build due to hygroscopic movements.
I thought that waterproof MDF was the stuff they use these days. This would be easy to cut and shape but tedious to paint. I have stuck a board down with Seriously Strong Stuff and that has not budged.
- big-all
- Pro Carpenter
yep dowel and glue one every 9 or so inches
10 min wood glue then you can free up the clamps after 2hrs in a cold workshop or an hour in the warm
will still be a bit delicate for an hour or 2 but will allow you to use the clamps again
http://www.toolstation.com/index.html?code=82652
Hey, thanks for that. I just cut a softwood plank to size to make a window board in my last house on a kitchen extension .. it warped to buggery.
Next question, if you were to use hard wood, what type would you go for?
I have some 20mm oak flooring left so I thought I might use that but I know that oak moves a fair bit. What do you reckon??
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
The thing to remember is that fine piece of wood is that shape because that's the shape we cut it to.skiking wrote:It amazes me that an inch or so thick piece of wood is going to curl up like that
I've got one to replace in the coming months. Glad to have got this info - hope I remember it !
If the wood decides it wants to be a different shape it will still be a fine piece of wood just not the shape we want.
If you think of it more that the wood hasn't warped it just more comfortable lying in a different position?
Jaeger.
