Bosch battery quetion?
Tinman
Post by Tinman »
Dont know this :oops: and dont know why i dont im sort of guessing the answer is yes :thumbright:
I have a 14.4v bosch drill/driver with 1.5 ah batteries which at present is doing the job for me but just!
My question is can i use other bosch 14.4v batteries that are higher in the ah levels if you get me :? like 2.0 ah / 2.2ah / 2.6ah /3.0 ah
or wont they fit my little 14.4v machine or will they burn it out?
And lastly will they last longer than my 1.5ah ?
Many thanks in advance for your help :thumbright:
[img]http://i2.photobucket.com/albums/y3/theflyingbanana/skull_left.gif[/img]
Jaeger_S2k
Pro Handyman
Has thanked: 21 times
Been thanked: 27 times
Post by Jaeger_S2k »
No problem just means greater hours of amps, it's last longer.
Just check the specs on your charger some are limited to the ah capacity they can charge.
Jaeger.
Has thanked: 740 times
Been thanked: 2355 times
just think of the ah[ as the fuel tank
if your 1.5ah battery lasts say 1.5 hrs [1 amp per1hr
your 3ah willl last 3hrs :thumbright:
Tinman
Post by Tinman »
Cheers guys :thumbright:
Just need to make sure i get correct fitment as there is a few diffrent shapes.
Fancy some 3.0h's :shock: keep thinking about dirty harry and his 44 magnum for some reason :lol:
Return to “Tool Talk”
