Hi all
I'm looking to get my hands on a manual for the SIP 8x4 planer/thicknesser. I can't find one online anywhere. Would be grateful if someone has a copy or point me in the right direction.
Andy
Help - SIP manual
- Has thanked: 10 times
- Been thanked: 8 times
- Has thanked: 807 times
- Been thanked: 3498 times
Re: Help - SIP manual
Hi DWD
I will possibly change them in about a month. Why do you ask?
Regards
Andy
Regards
Andy
I thought that with you asking for a user guide it might relate to your need to know how to set the blades.
I just wondered if you had a blade setting jig. It is a bit of a job getting the blades set and matching. On my Fox thicknesser I have a alignment guide which helps a bit it is a fiddly job. On my bench planer it is a bit easier as you have the outfeed table as a reference point.
Ask if you need any help
Hi DWD
I have the blade setting jig. I'll send you a message if I need any assistance. Appreciate it.
Andy
Andy
