Hi I've bought a Diamond disc for my angle grinder to cut a couple of tiles (got a proper manual type cutter for full length cuts)
But I had to rush in b&q as it was closing and I got one that says it's for brick/concrete will this do or will it just ruin the tile?
Dave
Diamond disc to cut tile
- Has thanked: 5 times
- Been thanked: 8 times
- Has thanked: 12 times
- Been thanked: 32 times
Re: Diamond disc to cut tile
It depends Dave,
If the blade is segmented it might chip the tile slightly when cutting it.
Tile cutting diamond blades are normally not segmented (or have tiny slits in the diamond segment), which gives a smoother cut.
Thanks for that, it does have but they arent huge, ill just give it a go and see what happens
