- Ultimate Handyman Forum Index DIY Forum/Home improvement Tiling Forum
- It is currently Thu Apr 17, 2025 5:33 pm
HELP! How do you guys deal with the cement?
- Jaeger_S2k
- Pro Handyman
- Has thanked: 21 times
- Been thanked: 27 times
Post by Jaeger_S2k »
So I've finished the utility room floor.
It's OK not fantastic but OK, I'll get some pics later.
This being my first I'm surprised how long it took me but it was good practice for the kitchen.
Some questions (yes more)...
How do you deal with the cement squeezing up between the tiles?
Do you cement the floor or the tiles?
Do you use the spacers at the corners of each tile?
I've got a 20mm oval trowel, is this right, or is there no right answer? just down to preference?
Jaeger.
Jaeger_S2k
- Rich-Ando
- Pro Tradesman
- Has thanked: 135 times
- Been thanked: 304 times
dunno how the others do it but i always use one fo the spaces to scrape the rapid set out from between the tiles. if you don't it sometimes shows through the grout.
as for the trowel, as far as i knew there was one depth for wall tile adhesive spreading and a deeper one for floor tile adhesive spreading.
as for "oval" dunno m8, only ever used the traditional ones.
some seem to use the spacers at the corners and some in between.
you spread the adhesive on the floor not the tile.
Rich-Ando
panlid
bathstyle
- Been thanked: 1 time
good tip about the anglebathstyle wrote:Always comb the adhesive at a 45 deg angle to the grout joints, don't push down too hard on the tile when bedding down
i find it helps if the floor is flat you are laying on. if it is all over the place its hard to get an equal spread meaning some spots are deeper adhesive which may need extra pushing down and like b says, more oozing out.
like everything else the more you do the more you get it right......
until you think youve got it sussed and it ends up all over your hands and clothes
panlid
Only-Me
- Jaeger_S2k
- Pro Handyman
Thanks guys,
I think my mix was a bit wet, even though I mixed the bag as instructions.
Bal Gold 10kg - 3ltr measured?
Should have ignoreded after first bag, but we do, we learn.
Cement on hands, clothes, tools ehhhhh.
The kitchen will be better, cementing the floor and use the spacers 2 per side ans slot them in, can't use them on the corners, have never done it that way but like you say OM as long as they work.
I'll try the angle to 'b' and a firmer mix should make a big difference.
Jaeger.
Jaeger_S2k
gaz
- Jaeger_S2k
- Pro Handyman
Hi gaz,gaz wrote:best way is to butt the tile your laying to the one already down, press down and pull out towards you, that way the addy wont come up through the joints
I was doing that as I progressed and it did make a difference, but the mix was definitely too wet.
All these new tips will be employed when I lay the kitchen floor.
Thanks everyone but do keep them coming.
Jaeger.
Jaeger_S2k
sorry if I'm hijacking the thread but I'm part way through a bathroom floor and the trowel I'm using is square-notched and small spaces (maybe about 3mm (edit - I think it is actually 6mm) 'cause I use it for walls too).
Is the trowel I'm using not correct?, 20mm u-shaped sounds massive but I don't want the tiles coming unstuck or breaking!! Any advice?
ps I'm laying 200x200mm tiles and I'll be laying 300x300 in my kitchen soon too.
Fraser
