how to install a breakfast bar
Locked
periklis_sale
Post by periklis_sale »
Hi guys
i am looking for your help....
i had installed a breakfast bar in the kitchen, attached one side on the wall (plaster boards with dry wall plugs for screws) and the other end with supporting legs. Unfortunately someone pushed the bar so one of the plugs came out of the wall so i will have to re-install it. What is the best way of doing it?
i was thinking to install a piece of wood with long screws (left over from kitchen wall cabinets) and screw the brackets (3 now not as before only 2) on the wood
What do you think? Any advice?
philrab66
Has thanked: 10 times
Been thanked: 14 times
Re: how to install a breakfast bar
Post by philrab66 »
You need to try and find the wooden studs in the wall and you could attach your timber to that , You should have at least one there or 2 if your lucky.Also you need to fix the leg.
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Is the wall studwork or plasterboard over block?
periklis_sale
thanks guys
i think the wall is plaster board on studs
but what will happen if the studs extend far away or offset from where i want to install the table?
it will be under the kichen window!
philrab66
Post by philrab66 »
if its under a window i would imagine there will be studs holding the window up.
Locked
Return to “Kitchen Fitting”
