I wonder if anyone can please tell me who supplies the cheapest flat pack?
We have all the normal suppliers in our area, Howdens, Magnet etc etc.... & of course the timber/builders merchants.
Is there any on-line suppliers you would recommend?
It's for a small basic kitchen in a let property, but the access is very limited, we have always done assembled units from Howdens in the past, but with this one we just wouldn't get them in the flat - it's so tight.
Also, what is the current going rate per unit for fitting flat pack?
Thanks for your help.
Flat pack
- Has thanked: 893 times
- Been thanked: 729 times
Flat pack
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
The Plumbers Anthem
Gas Safe RGI
- root
- Has thanked: 168 times
- Been thanked: 173 times
Re: Flat pack
http://www.diy-kitchens.com/ wouldnt know what people charge for installing flatpack stuff....
- Has thanked: 11 times
- Been thanked: 55 times
Re: Flat pack
At this present moment in time, if you get down to your local Focus DIY, their flat packs are dead cheap, and you can buy straight off the shelf. They're basic but good value, and have the best assembly instructions I've ever come across. The only flaw they have is where you attach the brackets (L-shaped ones) at back corners of unit, unless you pilot hole the fixing points into the carcass v. precisely, you will split the board and lose the corner of the unit - they're a little bit delicate there!
When you say going rate for fitting flat-pack, I'm not sure whether you mean the charge for assembling units or just general kitchen fitting? If its any help, units are about 15 mins each to build max. and in terms of what you charge, its going to be the fitting rate in your area. Somewhere between 140 and 200 a day I would say.
Best
Best
Re: Flat pack
Thanks gentlemen for taking the time to reply.Julian Cassell wrote:At this present moment in time, if you get down to your local Focus DIY, their flat packs are dead cheap, and you can buy straight off the shelf. They're basic but good value, and have the best assembly instructions I've ever come across. The only flaw they have is where you attach the brackets (L-shaped ones) at back corners of unit, unless you pilot hole the fixing points into the carcass v. precisely, you will split the board and lose the corner of the unit - they're a little bit delicate there!
Best
I would worry a little about buying from Focus Julian as they've just gone t.ts up!! I know B&Q have taken over some stores, but not them all. However, if their flat packs are very cheap I may take a punt.
Thanks again.
The Plumbers Anthem
Gas Safe RGI
The Plumbers Anthem
Gas Safe RGI
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
Re: Flat pack
Dickie,
We used Focus flat-pack five years ago for our kitchen refurb when we bought our Park Home. I know they are closing down but if you can get some from the shops before they all shut, they are fine.
We had no problems building and fitting them and it was only me and my wife plus the plumber for the sink fitting.
It looks good too. Ignore the floor covering, that went as soon as we had finished installing the units.
dave
dave
- Refurb (27) (Small).jpg (29.68 KiB) Viewed 2464 times
But you cannot tell him much.
Re: Flat pack
Hi Dickie, that's sort of what I was referring to when I said 'At this present moment in time', and because you can get them off the shelf, no need to wait etc. - As Dave M. says - simple to build etc.Julian Cassell wrote:I would worry a little about buying from Focus Julian as they've just gone t.ts up!
Cheers
- These users thanked the author Julian Cassell for the post:
- Dickie
