Matwell sizes
Posted: Sun Sep 30, 2007 6:41 pm
by Rogue
Am thinking of fitting a matwell inside the hall at my front door entrance. Floor in hall was going to be solid oak but now going for a heavy duty 12mm laminate. Have some heavy duty kids so that was the major factor in that decision!
What are the standard sizes for matwells and are they a good idea for breaching the step into a laminate floor from outside ?
Had intended to make up a frame so need to know what size it should be. Or would it be better to just leave an ordinary mat over the laminate?
Posted: Sun Sep 30, 2007 6:43 pm
by ultimatehandyman
I'd go for the second option, but would also use some of the anti slip tape to ensure that the mat does not slide ontop of the laminate.
Posted: Sun Sep 30, 2007 9:40 pm
by Rogue
Thanks UHM.
Just realised second option might stop my front door from opening due to the increase in floor height i.e. If I just put a mat on top of the floor then the door clearance will be tight. :cussing:
Posted: Sun Sep 30, 2007 9:59 pm
by Only-Me
Topps do matwell edgings.......you cut to size :thumbright:
Posted: Sun Sep 30, 2007 10:28 pm
by tim'll fix it
you can buy coconut matting at a carpet shop which you can get cut to any size
