Fitting a floating mantlepeice
Posted: Mon Oct 01, 2007 10:56 am
by Fraser
I am intending to fit a oak beam (4"x5"x40") as a mantle on a chimney breast (by the way the fire is not used).
What's the best way to do this considering the timber is solid?
I was thinking of using 3 or so short, large diameter dowels screwed to the masonary then drilling holes in the rear of the beam and gluing the beam onto the dowels (does that make sense?).
Anyone done anything similar or know of any other methods??
Cheers
Posted: Mon Oct 01, 2007 6:30 pm
by Wood Magnet
What do you mean by "Dowels", if you mean wood dowels it's a no no, you need threaded steel bar for the "Dowels" and three should be o.k. but personally i always err on the side of caution so i would use four. :wink:
Posted: Mon Oct 01, 2007 6:42 pm
by Hitch
Steel studding fixed into the wall, 10mm diameter, Drill the holes in the shelf to suit, but nice and tight, and push over the studding.
You could drill the shelf slighty larger and put a bit of gripfill in the holes to secure it. But it wont be coming off again.
Posted: Tue Oct 02, 2007 8:48 am
by Fraser
Cheers for the suggestions. I did mean wood but I'll change that for steel bar now :thumbright:
Posted: Tue Oct 02, 2007 4:26 pm
by Wood Magnet
Your welcome Fraser, and thanks for replying. :thumbright:
Posted: Wed Oct 03, 2007 12:14 pm
by Fraser
Okay, I've got myself some 10mm steel studding.
What's the best way to fix it to the masonary? The threads on the studding don't look like they'd bite into wall plugs - my initial plan was to use fischer wall plugs (60mm long) into 12mm drilled holes in brickwork (covered in plaster by the way) and then screw in the studding, but now I'm not sure?
Posted: Wed Oct 03, 2007 5:13 pm
by Wood Magnet
Drill a hole stick some gripfill in and then the rod,
once it's set you're ready for the timber, then just repeat
the process. :thumbright:
Posted: Wed Oct 03, 2007 7:30 pm
by Hitch
Yes, as its only a shelf, some gripfill in the holes will suffice. Take care not to drill right through the brickwork, of it will just keep pushing it out the back :wink:
Drill the holes as square as possible.
Id be inclined to fix the studs in the wall, then drill the shelf to suit, incase you need to move any of the holes.
Posted: Thu Oct 04, 2007 9:24 am
by Fraser
Nice one, I'll post a pic once I have done it.
Posted: Thu Oct 04, 2007 9:31 am
by ultimatehandyman
Fraser wrote:Nice one, I'll post a pic once I have done it.
Nice one :thumbright:
Good luck with it :wink:
Posted: Thu Oct 04, 2007 4:42 pm
by Wood Magnet
Looking forward to it Fraser. :wink:
Posted: Mon Oct 15, 2007 9:30 pm
by Fraser
I fitted it last weekend...
M10 steel studding from screwfix hacksaw-ed into 4x180mm lengths. 10 mm drill into brick x80mm and 10mm drill into wood x100mm. Bit of gripfill in every hole = solid as a rock.
It's level too :grin:
I used a paper template to get the holes in the same place for wall and wood.
Cheers again for the suggestions.
Posted: Mon Oct 15, 2007 9:35 pm
by Hitch
Nice one Fraser :thumbright:
Posted: Mon Oct 15, 2007 11:34 pm
by Wood Magnet
Well done Fraser :-) ,and thanks for showing the picture. :thumbright:
Posted: Tue Oct 16, 2007 3:43 am
by ultimatehandyman
Well done Fraser- looks great :thumbright:
