BT Wiring Help.....with photos.....complete novice!!!!!
Telecommunications, Broadband and networking questions in this forum please
Locked
k_mac65uk
Post by k_mac65uk »
Hi all,
I am having abit of trouble with my Broadband and Phone and think its the line extension thats causing it!
I've tried connecting the phone Directly into the Master Socket and get the same problem but when I remove the cover and plug it into the Test Socket it works perfectly well!!!!
I'm thinking there is a wiring problem as I have one loose Orange/White!!!
BT are wanting to charge £130 just to knock on my door but I'm guessing it's just a simple fix I can probably do myself with the right information!
2011-07-01 15.24.16.jpg (431.1 KiB) Viewed 3236 times
2011-07-01 15.25.16.jpg (418.78 KiB) Viewed 3236 times
2011-07-01 15.24.32.jpg (377.25 KiB) Viewed 3236 times
Any help will be greatly appreciate
gas4you
Has thanked: 419 times
Been thanked: 900 times
Re: BT Wiring Help.....with photos.....complete novice!!!!!
Post by gas4you »
One of the experts will be along soon, but in the meantime AFAIK the only 2 connectors used are 2 & 5, so what ever one is empty, assume this is where it has fallen out of.
Dave
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
Not an expert but my Son recently bought a plug in extension kit from Maplin; wired up new wall socket per diagram and it did not work, told him to just connect pin 2 and 5 per diagram and presto works. Good read:
http://www.wppltd.demon.co.uk/WPP/Wirin ... phone.html
Locked
Return to “communications and broadband”
