Setting out with a level baton - what do YOU use ?
Posted: Sun Jul 03, 2011 8:41 am
OK, so you are about to start tiling and want to fix a baton to tile up from.
What do you use as a baton - So often a piece of timber is not straight enough and I have often wondered if there is not something better, like aluminium trim or whatever - something that is actually straight, can be cleaned off and reused easily, and cut to fit.
I sort of imagine that there must be some product on the market that has adjustable legs to allow for leveling it up accurately, maybe some sort of suction/sucker that will fix it to any surface and a replaceable straight 'top' that can be cut, cleaned and replaced as needed to allow fir different length runs.
Is there such a thing, or do you all just use any old offcut of roofing baton and sort things out as you go along ?
