Right Angle Drill Adaptor
The Bargain Tool forum. This is for regular members to post about bargain tools. It is not for spammers to post links to tool sites!
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Post by dave.m »
At Aldi from Thursday:
For £5 must be worth having one in your toolbox.
Choose from: keyed or keyless drill adaptor, both feature side handle (can be screwed on either side)
Right Angled Adaptor.jpg (46.86 KiB) Viewed 3131 times
But you cannot tell him much.
Has thanked: 827 times
Been thanked: 3601 times
Re: Right Angle Drill Adaptor
Must get one of those. I could have done with one last week. :thumbright:
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Got one from Aldi a couple of years ago..... came in a snazzy ali-coated box
dave.m
Post by dave.m »
Just came on cardboard this time with a plastic bubble over it.
Got the keyless chuck one this morning and tried it out on a few screws that were "inaccessable" (well I pretended they were)
It took a few minutes to figure out the best side to fit the grip handle and then had to start the driver slowly to work out which way the torque would try to turn it but it worked fine.
Remember if using it to UNscrew in a tight corner to make sure you leave enough room for the screw to come part way out of the hole.
Quite pleased with it for the price. Feels heavy enough to have metal gears rather than cheapo plastic ones.
Will probably sit in the tool bag for a couple of years before getting used in earnest but for 5 quid . . . money well spent (less than two pints).
dave
lagi
Has thanked: 141 times
Been thanked: 53 times
Post by lagi »
Did see this, what is the length please so we know how small a gap it will fit into?
dave.m
Post by dave.m »
With a short screwdriver bit in the chuck it is 145mm from tip to back of elbow.
So to screw in a 1" screw you would need about 7" clearance.
This is with the keyless chuck, but the keyed chuck looked about the same length.
dave
I just got one of the keyless chuck versions too. Seems well made and I am sure that it will last a long time with the occasional use expected. For £5 it is well worth it.
I notice next week they have an 800w generator for £70 which might be worth a look
root
Has thanked: 168 times
Been thanked: 173 times
Post by root »
ooo
- Dave
Return to “Bargain Tools”
