It's Arrived!
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- thescruff
Re: Deleted
Bloody quick
Have Firefox and thunderbird up and running so emails are working.
The wireless network is next, may have a can of Fosters and a bite to eat first.
Hate the keyboard, got use to the laptops I fear.
I want a digital keyboard assuming you can get them.
Going to see if I can connect the laptop with a usb cable later.
- thescruff
Re: It's Arrived!
Thank you mod 5
I'm sure we haven't heard the last of it.
Is there a spell checker in 7
- chat_to_rich
- Been thanked: 45 times
Re: It's Arrived!
There isn't a spell checker built into Win7. They're part of the programs. What program do you need a spell checker for?
- thescruff
- thescruff
Re: It's Arrived!
What's the difference between usb 2 and the new usb 3, seems to work in either.
What's "sata" for.
Should there be an office program in 7 Pro, word, excel etc, or what do you guys use.
What's "sata" for.
- EJJ150847
- Has thanked: 35 times
- Been thanked: 188 times
Re: It's Arrived!
Serial ATA (SATA or Serial Advanced Technology Attachment) is a computer bus interface for connecting host bus adapters to mass storage devices such as hard disk drives and optical drives. Serial ATA was designed to replace the older ATA (AT Attachment) standard (also known as EIDE), offering several advantages over the older parallel ATA (PATA) interface: reduced cable-bulk and cost (7 conductors versus 40), native hot swapping, faster data transfer through higher signalling rates, and more efficient transfer through an (optional) I/O queuing protocol.
From WKIK Too lazy to look yourself old man
John
John
- wine~o
- Has thanked: 1414 times
- Been thanked: 4019 times
Re: It's Arrived!
EJJ150847 wrote:
From WIKI Too lazy to look yourself old man
John
Or too busy playing with his new toy....
- thescruff
Re: It's Arrived!
So should I rush out and find something to plug in them John.
How about the other questions.
On the old one at the moment wine~o, need to figure the easiest way of transferring the data from the laptop over, could probably plug the HD in my remote HD.
Also need to sort work, excel etc.
- wine~o
Re: It's Arrived!
Think windows 7 gives you something called "Easy transfer"..should run on first start up with a question like "Is this your new computer"?....you can use this to import/export files....
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
Re: It's Arrived!
Get the appropriate version of Easy Transfer for your OLD version of Windows from
http://windows.microsoft.com/en-US/wind ... y-transfer
Install it on you laptop then follow the instructions in the links at the bottom of that page. Simple and Easy.
You can do it, Scruff.
In Win 7 you should find the Easy Transfer under Start -> Accessories -> System tools. . . .
or just click Start button and type 'easy transfer in the search box just above the Start button where it says 'search progs and files'
It will show Windows Easy Transfer in the Programs search results, just click it to open it. But install the easy transfer on your laptop first and then watch the video in that link to show you how easy it is to do.
dave
dave
But you cannot tell him much.
- thescruff
Re: It's Arrived!
Thanks again,
Got to find something to open the files and folders first.
Adobe will be good for the pdf.
May see if it will take office 2000.
- dave.m
Re: It's Arrived!
Use Foxit Reader for your PDFs.
Office 2000 is compatible with Windows 7 BUT Outlook 2000 will not work on Win 7.
If you have Office 2000 on a disc then install it to use but why not get Thunderbird v5
You should be able to export your Contacts from Outlook to a USB stick then import to the new PC.
dave
dave
