How to remove paint stains and rusty spots from a floor tile
Terry52
Post by Terry52 »
We did a paint job on the balcony recently and spilt some of paint on a tiled floor.
Should have cleaned it quickly but we didn't - so ended up with some paint stains on the
tiles.
Can you recomentd a solvent and the tools to get rid of the stains - tried to use the aceton
but it didn't help much.
If it could remove the rusty spots - that would be just great.
I have attached the pictures of stained tiles and how a clean one looks like ;-)
Thanks for your time guys.
Terry,
I have embedded the pictures in this post rather than using an outside hosting site.
mod5
with paint stains
with paint stains
1 paint stains.jpg (56.77 KiB) Viewed 1053 times
with paint stains
with paint stains
2 paint stains.jpg (60.08 KiB) Viewed 1053 times
With rust stains
With rust stains
3 with rust.jpg (70.39 KiB) Viewed 1053 times
This is a clean one
This is a clean one
4 clean.jpg (75.8 KiB) Viewed 1053 times
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: How to remove paint stains and rusty spots from a floor
Post by ayjay »
What type of paint was it ? Whatever was used for cleaning the brushes will be the solvent you should try first.
Speaking as an amateur potter I'd be surprised if you find anything to remove the iron oxide (rust), it is widely used as a stain in many applications and survives firing to beyond 1300°C.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
You could try this for the rust removal- remove rust from stone
Return to “Tiling Forum”
