Diamond Pattern
Rusty10
Has thanked: 9 times
Diamond Pattern
Post by Rusty10 »
Hi everyone
Will be embarking on another phase of the learning curve that is renovating! Firstly thank you to everyone here who has helped with good advice and endless tips :thumbright:
As the title says, I am planning a diamond patterned floor for the utility, not a big area and will be using 600x600mm tiles. My thinking was to start in the middle of the room with a whole tile (turned 45deg) and work my way from there? I have ordered a T5 angle finder and was hoping for any top tips any of you pro's might have to help me?
Thanks in advance :)
amarg
Has thanked: 12 times
Been thanked: 32 times
Re: Diamond Pattern
Post by amarg »
With tiles that big you will have to ensure that the floor is dead level.
The larger the tile the more difficult it is to get them level.
Also some tile cutters do not cut diagonals well, so you will need a decent tile cutter
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Diamond Pattern
Post by royaloakcarpentry »
Middle of the room, from middle of door, middle of something else...................depends on lay out of room and how cuts work out.
Diagonals normally look better in a larger room.
m3 fitter
Tiling Expert
Has thanked: 7 times
Been thanked: 14 times
Re: Diamond Pattern
Post by m3 fitter »
To set out a diagonal floor, centre the room ie: mark the middle of the floor at each end, draw your central line joining up these marks, then centre the other way, your first tile should be centred totally from point to point on your first central line ( this is sounding complicated!)
The best scribe cutter for this project will be a TX1200 ( good tile shops hire these daily ) as you can use the breaker on any part of the tile, with any diagonal pattern, a soldier corse or border works better as you can deternine your own cuts as opposed to being forced into silly triangles ie: half tile cuts with a 150mm border etc.
make sure your substrate is totally level, a self levelling compound is recommended prior to tiling to avoid lipping ( raised edges of tiles), and use a minimum of 10mm trowel, also use a 600mm spirit level on each and every tile to avoid increasing or decreasing heights. usually these days 600mm x 600mm are porcelain and rectified edge, not for the faint hearted or unexperienced, especially on the diagonal. Good luck with your project, well achievable but it will be challenging.
royaloakcarpentry
Re: Diamond Pattern
M3 fitter...............Is that a pic of your new Rubi??
Looks more hassle than a Sigma, but a good price in Nichols and Clarke. TXN 700 it looks like but can't remember if they are £336. Does ring a bell, that price. (alarm bells lol)
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: Diamond Pattern
Post by ayjay »
Mainly aimed at the OP for reassurance, they can look OK for a small area too, (I was doubtful when someone suggested it), so I tried these both ways and they actually looked better on the diagonal.
Sorry, couldn't wait for the wife to get the broom out. :B
IMG_4524 modified.jpg (389.36 KiB) Viewed 1630 times
m3 fitter
Tiling Expert
Re: Diamond Pattern
Post by m3 fitter »
royaloakcarpentry wrote:M3 fitter...............Is that a pic of your new Rubi??
hahha i wish... try TX1500, treble that cost and more !! for Porcite Dos Roble 1300mm x 176 and 252 mm planked porcelain, an updated version of the 1000mm planks!! here http://www.ascottiling.co.uk/porcelain-wood-effect.html
royaloakcarpentry
Re: Diamond Pattern
One of our tilers has a few quid invested in cutters.
I remember that job from the showcase gallery.
Rusty10
Re: Diamond Pattern
Post by Rusty10 »
Thanks for all you helpful advice, will give it a go this w/e and report back!
Return to “Tiling Forum”
