Recording can select frequency?
- Has thanked: 43 times
I have successfully recorded my voice by computer + Sound Recorder+ microphone .
However, I fail to record noise from the pipes in my flat even though the noise was more aloud than my voice and I put the microphone very close to the pipe.
Thank you in advance.
- RichieP
- UHM Super Moderator
- Has thanked: 4 times
- Been thanked: 12 times
Re: Recording can select frequency?
In that case it's obvious that the noise isn't audible to anyone or anything else.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
I wouldn't get too obsessed about the noises from the pipes.
Unless they are saying BURN, KILL, DESTROY etc
- root
- Has thanked: 168 times
- Been thanked: 173 times
is the noise in the pipes or is it actually some other central location? its not a neighbours washing machine or dryer rattling them?
- Dave
- Megaross
- Has thanked: 28 times
- Been thanked: 110 times
Knew it wouldn't pick the noise up, not to be a smug b*stard or anything.
Another option would maybe be to film it using a video camera and extract the noise from the recording, the microphones are better at picking up stuff other than speech. Might take some trial and error with the timings etc. Just something else to try.
That microphone can only pick sound very close to it. I set it very close to the pipes but cannot record anything.....means the noise is not from the pipes? My ears told me the noise is from the pipes....What I can do???
