Cheap router table and other tools
The Bargain Tool forum. This is for regular members to post about bargain tools. It is not for spammers to post links to tool sites!
Has thanked: 823 times
Been thanked: 3562 times
This router table at £30 must be a bargain for those of you who would like to extend the use of your router.
http://www.aldi.co.uk/uk/html/offers/sp ... _20629.htm
There is also a cheap box of cutters worth it for sacrificial jobs that knock them out http://www.aldi.co.uk/uk/html/offers/sp ... _20628.htm
And a cheap belt sander well worth £20 http://www.aldi.co.uk/uk/html/offers/sp ... _20630.htm
And finally some cheap detail and belt sanding sheets http://www.aldi.co.uk/uk/html/offers/sp ... _20631.htm
There are some other good deal too http://www.aldi.co.uk/uk/html/offers/of ... nday11.htm
All from tomorrow :thumbright:
These users thanked the author dewaltdisney for the post (total 3):
big-allBRUNOzedhead
Rating: 21.43%
Has thanked: 736 times
Been thanked: 2341 times
Re: Cheap router table and other tools
nice find dwd :thumbright: :thumbright:
all i would add is if you buy the delta sheets for your bosh 180 multitool or similar check they stick as i had some lidl ones and the velcro is different so the would not stick
Megaross
Has thanked: 28 times
Been thanked: 110 times
Post by Megaross »
Ahh I love aldi, just bought a lovely shiny dewalt router, should go nicely.
holy85
Has thanked: 17 times
Been thanked: 2 times
Post by holy85 »
I bought the router, it really is cheap. The height adjustment knob on the router broke before even using it. Have to go back and get my money back. The router table and bits are fine.
Shame about the router. Let us know how you get on with the table when you get your router sorted :thumbright:
holy85
Post by holy85 »
I ended up fixing my old router, and when clamping it down it seems firm, but when it came to routing a piece on the table I could see some play in the router. I'm guessing the router table only works best with it's own brand of router. I will give it another go tomorrow.
there should be no play[less than say 0.25mm]in the total setup
if you have more movement something is wrong
you often have to drill extra holes to give firm fixings but virtually any router will work with any table the only difference being 1/4 inch and half inch
Did you use machine screws to fix it to the table? Routers have threaded holes for this purpose in the base and sometimes you have to drill extra holes in the table to get the router firmly affixed. :thumbright:
holy85
Post by holy85 »
I'll look into that, :thumbleft: as i didn't use any screws, I only used the 4 camps on the table.
if the table uses clamps then normally that is suffice
can you try and work out where the play is ??
Stoday
Deceased 21-10-2011 R.I.P
Has thanked: 8 times
Been thanked: 90 times
Post by Stoday »
That router table looks like the B&Q McAllister table.
Useless.
My comments apply to the B&Q so may not apply to this table. Anyway, for the B&Q version you have to demount the router to change the bit. That's cos they've put screens up so your fingers can't get caught under the table. Also setting the height of the bit is very difficult.
I bought a new table. I haven't quite got around to throwing the old table away, so if anyone wants it I'll give tit to them. They can pick it up from Ipswich for free.
StanleyW
Has thanked: 12 times
Post by StanleyW »
I bought the table and bits and use them with a Dewalt router. So far only used it to make 5 hardwood newell post caps but it worked fine on them. The table was cheaper than the quote I got from the local wood merchant to make the caps. You can change the bit with the Dewalt fixed to the table but it is a bit fiddly. The router did not move when held by the 4 table clamps but this was not a particularly difficult job.
Good result Stan, thanks for the feedback :thumbright:
Return to “Bargain Tools”
