tiling adhesive and grout
dave195
Post by dave195 »
Hi.
I have recently tiled my kitchen and I am now wondering if I should have used an a white pre-mixed adhesive/grout rather than a seperate adhesive and grout because there are signs of the greyish adhesive on some edges of the tiles and this slightly spoils the appearance of a really good job.
Any advice or opinions are most welcome
Cheers
Dave 195
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Re: tiling adhesive and grout
Post by Colour Republic »
All in one addy and groutd rubbish, the bucket it comes is worth more than the stuff inside
Use bagged adhesive in grey if you work cleanly or a White bagged adhesive if you need something a bit more forgiving (some natural stone tiles also require a whit adhesive so it doesn't stain through the tile)
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Clean the work as you go along. If you don't then the only option is to go around with a stanley knife and clean off any snots of adhesive from tile edges before you grout.
ali.shout1
Post by ali.shout1 »
in my experience its always best to ask the tile retailer what their favoured grout is... failing that, certainley get a grout that roughly matches the colour of the tiles...
m3 fitter
Tiling Expert
Has thanked: 7 times
Been thanked: 14 times
Post by m3 fitter »
As a rule of thumb, match the adhesive to the grout ie: dark grout = grey adhesive and vice versa, saves time after fixing and prior to grouting cleaning up the joints if deep bedding etc.
NEVER USE FIX AND GROUT READY MIXED
m3 fitter
Tiling Expert
Post by m3 fitter »
ali.shout1 wrote:in my experience its always best to ask the tile retailer what their favoured grout is... failing that, certainley get a grout that roughly matches the colour of the tiles...
Got to a project where it was labour only, the materials on site already, the shop had supplied grey flex adhesive, white 600x300 porcelain and white grout...hmmmmm!!! I exchanged the adhesive, retailers don't always think as they just sell it
Return to “Tiling Forum”
