More Alt + codes
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
More Alt + codes
I have discovered some more Alt codes whereby holding down the Alt key and typing a number in will produce symbols.
Some of these may be of use to members when doing quotes or adding text to drawings.
These will only work when entered using a number keypad (to the right on your keyboard) with the Numbers Lock ON.
They will NOT work with the number keys above the letters on a keyboard.
If using a laptop without a numbers keypad then an external keypad can be used but the Alt+ Number code must be followed by keying ‘Enter’
Alt Codes.
Alt + 0188 = ¼
Alt + 0189 = ½
Alt + 0190 = ¾
Alt + 248 = °
Alt + 0176 = °
Alt + 0185 = ¹
Alt + 0178 = ²
Alt + 0179 = ³
Alt + 246 = ÷
Alt + 0247 = ÷
Alt + 13 = ♪
Alt + 14 = ♫
Alt + 0169 = ©
Alt + 0174 = ®
Alt + 0153 = ™
Alt + 0149 = •
Alt + 16 = ►
Alt + 17 = ◄
Alt + 30 = ▲
Alt + 31 = ▼
Alt + 19 = ‼ Double Exclamation Mark
Alt + 20 = ¶ Pilcrow (Paragraph Sign)
Alt + 21 = §
Alt + 22 = ▬ Long and Thick Minus Sign
Alt + 23 = ↨
Alt + 24 = ↑
Alt + 25 = ↓
Alt + 26 = →
Alt + 27 = ←
Alt + 28 = ∟
Alt + 29 = ↔
Alt + 0176 = ° (Degrees)
Alt + 0162 = ¢
Alt + 0163 = £
Alt + 0165 = ¥
Alt + 0177 = ±
Alt + 0166 = ¦
Alt + 0149 = •
Alt + 0134 = †
Alt + 0227 = ã
Alt + 0151 = — (m dash)
Alt + 0150 = – (n dash)
Alt + 8 = ◘
Alt + 9 = ○
Alt + 10 = ◙
Alt + 11 = ♂
Alt + 12 = ♀
Alt Codes.
Alt + 0188 = ¼
Alt + 0189 = ½
Alt + 0190 = ¾
Alt + 248 = °
Alt + 0176 = °
Alt + 0185 = ¹
Alt + 0178 = ²
Alt + 0179 = ³
Alt + 246 = ÷
Alt + 0247 = ÷
Alt + 13 = ♪
Alt + 14 = ♫
Alt + 0169 = ©
Alt + 0174 = ®
Alt + 0153 = ™
Alt + 0149 = •
Alt + 16 = ►
Alt + 17 = ◄
Alt + 30 = ▲
Alt + 31 = ▼
Alt + 21 = §
Alt + 23 = ↨
Alt + 24 = ↑
Alt + 25 = ↓
Alt + 26 = →
Alt + 27 = ←
Alt + 28 = ∟
Alt + 29 = ↔
Alt + 0162 = ¢
Alt + 0163 = £
Alt + 0165 = ¥
Alt + 0177 = ±
Alt + 0166 = ¦
Alt + 0149 = •
Alt + 0134 = †
Alt + 0227 = ã
Alt + 8 = ◘
Alt + 9 = ○
Alt + 10 = ◙
Alt + 11 = ♂
Alt + 12 = ♀
- These users thanked the author dave.m for the post (total 3):
- Mooncat • Razor • AAA.Handy.Man
- Rating: 21.43%
But you cannot tell him much.
- dave.m
Re: More Alt + codes
For any Poker players amongst you:
Alt + 3 = ♥
Alt + 4 = ♦
Alt + 5 = ♣
Alt + 6 = ♠
Alt + 3 = ♥
Alt + 4 = ♦
Alt + 5 = ♣
Alt + 6 = ♠
- Has thanked: 77 times
- Been thanked: 335 times
That ¢, is that meant to be a centre line symbol of some archaic currency symbol or something?
Pi symbol would be handy Dave, Musical note one is close, but not quite
- Mooncat
- Has thanked: 81 times
- Been thanked: 72 times
→Very good info, I'll print it out.
- dave.m
Hitch,Hitch wrote:That ¢, is that meant to be a centre line symbol of some archaic currency symbol or something?
The ¢ is supposed to be the symbol for centre line and is used by some to indicate circumference measurements, but, as a one-time draughtsman I always used it to indicate the centre line of a component that I was drawing. Especially if one half of the drawing was a sectional and the other half was full face.
As for Pi, I am looking.
Edit:
Alt + 227 used to show as Pi but not now, don't know why.
dave
- Mooncat
The caret over a vowel is what I need, including the w and y. Is it possible?
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
Üaÿå
w y
aÞ wÞ...nope not a scoobie
w y
- Has thanked: 63 times
- Been thanked: 59 times
No "w" and "y" but the vowels are here:Mooncat wrote:The caret over a vowel is what I need, including the w and y. Is it possible?
http://www.starr.net/is/type/altnum.htm
http://www.starr.net/is/type/kbh.html
Edit: They're here: http://www.starr.net/is/type/htmlcodes.html
wrinx
- dave.m
MC,
The instructions in this link do not work on my Win 7 but don‘t know which OS you have:
Typing the Welsh Circumflex Using standard Microsoft shortcuts or commands
So try this:
Open a MS Word document and go to where you wish to insert the letter with a circumflex.
Click Insert (on the toolbar) -> select Special Characters.
In the window that opens, drop the menu and select which font you are using (eg Arial)
The chart will change to display what symbols are available in that font.
Click on which letter you want (upper or lower case) and click Insert.
Â Ê Î Ô Û â ê î ô û
As for the w and y, there is a section in the above link that may work for you.
I tried my best but failed at the last hurdle of ŵ & ŷ
You can copy and paste these two if you wish.
dave
So try this:
Â Ê Î Ô Û â ê î ô û
dave
- dave.m
Thanks to Wrinx,
These are the Alt codes to add to your list:
Alt
+ 0194 = Â
+ 0226 = â
+ 0202 = Ê
+ 0234 = ê
+ 0206 = Î
+ 0238 = î
+ 0212 = Ô
+ 0244 = ô
+ 0219 = Û
+ 0251 = û
The Welsh W and y do not show in the list.
Alt
+ 0194 = Â
+ 0226 = â
+ 0202 = Ê
+ 0234 = ê
+ 0206 = Î
+ 0238 = î
+ 0212 = Ô
+ 0244 = ô
+ 0219 = Û
+ 0251 = û
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Ŵ ŵ Ŷ ŷ
dont know if it work but here goes
try them on your comp MC
http://gwybodiadur.tripod.com/software.htm
- dave.m
The HTML codes don't work on here nor in MS Word, BUT that is a good link, John.
There are a couple of good links to some free font downloads under the "WELSH FONTS" heading.
dave
dave
- thescruff
