Manual Required
- Argyll
- Has thanked: 1185 times
- Been thanked: 582 times
Manual Required
A work colleague requires a user manual for a WB 280 Combi. There is an installation manual on this site for a WB RSF 280. I'm assuming it's the same boiler.
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Re: Manual Required
If you know the GCNo it can be checked.
The RSF280 is GCNo 47-311-11.
Have attached the User manual
- 280 RSF USER.pdf
- (157.1 KiB) Downloaded 534 times
- Argyll
- thescruff
Re: Manual Required
It's the Gas Council Number that ID's all boiler except a few importsArgyll wrote:Thanks mate but what's the GCNo? Is this the serial no?
- Argyll
Re: Manual Required
He reckons his is slightly different so I've asked him for the GCNO as you requested. Can you tell me where it is normally found?
- thescruff
Re: Manual Required
Should be on the data plate inside the door/case
It's probably close enough depending what you want.
