Kitchen floor tiles: making good the grout
Webby Bear
Has thanked: 7 times
Been thanked: 2 times
Post by Webby Bear »
Hi All, hope you're well.
Firstly, I'd like to point out that I am not the worlds best DIYer so please forgive me if I say something silly :lol:
In short I tiled my kitchen floor about 6 months ago. I grouted and holding my hands up I made a poor job of it. I used 7mm spacers and I put too much grout in and although it looks ''ok-ish'' I now have the time to remedy.
There's grout obviously in the gaps but some I have covered the edge of the tile. Also I didn't put any sealant stuff on the grout so it has got filthy (beige to almost black :oops: :oops: :oops: :oops: )
To sort this out I was thinking of getting the mouse sander out with coarse paper. Sand the grout lines including the edges I've gone over to remove the grout. Then presumably Topps sell some sort of sealant so dirt and grime won't stick to the grout?
Any info you can give me would be much appreciated.
Cheers.
Bear.
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Re: Kitchen floor tiles: making good the grout
Post by Rich-Ando »
i wouldn't use sandpaper. there are proper grout scraping tools for the job and they arn't expensive to buy. get the one with the diamond blade, the rake is useless.
depending on what type of tile you have will depend on how you try to remove the grout from the edges of them. there are also grout removing solutions you can buy.
for sealants look for HG sealant
These users thanked the author Rich-Ando for the post:
Webby Bear
Webby Bear
cheers rich.
i attempted a ''test area'' with a flat head screw driver. that worked but would take a while i imagine.
is there any drill attachmednts that would do the same thing? i am lazy! :lol:
Rich-Ando
Pro Tradesman
Post by Rich-Ando »
sorry you need to do it by hand or risk damaging your tiles
m3 fitter
Tiling Expert
Been thanked: 14 times
Post by m3 fitter »
Use LTP grout sealant comes in 600ml spray cans, easier than HG dropper method ( madness!! ) http://ltp-online.co.uk/images/p_grout_ ... erosol.jpg usually covers approx 20 m2, with a 7mm spacer say 12-15 sq.metres, hope it helps
Webby Bear
cheers for all the help guys. ive done half of it tonight using a flat head screw driver. much better looking when its all done. just got bit of arm ache now lol
Webby Bear
well finally finished the ''chissling'' :roll:
i got half way round and was so shattered i pulled out the coarse sand paper.workked an absolute treat!!!!! and took so much less time. :huray:
now ive just got to apply the grout protector......... £18 a bottle!! :shock: :shock: :shock:
thanks for all ya help guys :salute:
Return to “Tiling Forum”
