Bosch GBH 4 DFE Multi Drill
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
The bosch Multi drill is the mother of all DIY drills.
It's a large drill and so using it in confined spaces or up ladders is very difficult. The safety clutch is a useful feature, although it tends to make hard work of using diamond core drills.
2 chucks are supplied as standard but I only ever use the SDS chuck. The machine is powerful and can make light work of most jobs. Rotary stop means that you can use the drill for chiselling and apparently you can use if for punching nails in.
I bought the drill off ebay as I had seen them for sale in several places but could not justify the almost £300 price tag.
The only thing you can't do with the drill is put screws in! I have not tried to chisel wood with it yet either.
Here is the full spec-
.Power input 750w
.No load speed 0-650rpm
.Impacts per Minute 0-3950
.Single impact force 3.5J
.Variable speed
.Maximum Drilling Capacity with SDS-plus Bits (Concrete) 4-30mm, With Vacuum Bits & Dust Extraction 24mm, Maximum Drilling Capacity using chuck in Steel 13mm, using chuck in wood 30mm, Recommended Drilling Range 8-24mm, Drilling performance in concrete 8-24mm
.Supplied with 1/2â€
.Power input 750w
.Variable speed
Last edited by ultimatehandyman on Wed May 09, 2007 3:45 pm, edited 1 time in total.
